w00tmaster
165
It seems the contacts on my iBook is broken and I was wondering if anyone else had this problem. When I plug the power into the iBook, the light turns orange, but usually it won't actually charage the iBook(the battery icon in the upper right doesn't change), however if I jiggle the connector I can get it to charge, but if it moves slightly then it goes back to running off the battery. It's still under warranty(for another month), but do you think I need to?
Well... if you don't do it before the month is over you'll probably regret it. Just see about getting it fixed. My iBook G4 is fine but we all do different things with out machines...
