Kirjava444
65
Hello,
I've recently acquired a Snow iMac G3 running Tiger. It is working well, however I noticed that occasionally when I plug in a USB device (I have tried a few different ones), it will power off. This also happened once when I just tapped the area near the USB ports. I am curious to know if the location of the power supply is close enough to the USB ports that it could be a bit loose and I could be occasionally knocking it a bit when I plug in a device?
Thank you
