MrMister111
macrumors 68040
3,904
382
UK
I’m (still) looking for a clear case for iPhone 14 Pro that has the following. I’ve ordered a few from Amazon UK and had to send back.
Clear/transparent
MagSafe or not, either
Thin as can
No front wrap around front (find it sometimes interferes with screen protectors)
No bumpers on corners, just smooth all around edge.
Soft cases, don’t like the hard plastic type.
This is not a case for protection just an option for clear case as I still like to stop scratches.
Thanks
just get a skin that has the front, back and sides if you don’t care about protection. Slickwraps has clear ones I think.
Clear/transparent
Thin as can
Thanks
I’m in the same position, my phone arrives next week and I can’t decide whether to get a minimal transparent soft case (no MagSafe as I think it looks horrible on a clear case), a soft clear bumper with glass proof protection back and front, a skin (possibly XtremeSkins) or just using it naked. I’ve read all threads on the subject and can’t find much interesting, especially as many aren’t available in the UK.
Just put a wallet of your choice over that ugly round ring with a tail. Works pretty well.
If I either used or wanted a wallet then yes, a good idea. Unfortunately I have no use for a wallet that doesn’t hold cash, both notes and coins.
Clear/transparent
Thin as can
Thanks
https://www.totalleecase.com/products/iphone-14-pro-case?variant=39869664919614
This seems to be the closest I can find to what you’re looking for.
Very similar to the one before my post but another option maybe?
I have this. It's not soft, can be kind of slippery as a result (not as bad as the Apple clear case) and has this weird split at each of the bottom corners. Plus the buttons are cutouts, so they end up recessed. Overall wouldn't recommend it, certainly not for the price. Plus, if you order from them directly, it takes them eons to even ship.
