mustu
425
46
Hello
I have a iphone 14 pro max and and 13 mini.
Now on both phones after one ring it will go to voice mail. I have 2 numbers on each phone it happens to all of them - including FaceTime. what's app calling works and i gets multiple rings as normal.
Now I checked DND , block callers etc all the possible things, I reset Network settings and it started to work but as soon as i connected to the house Wifi it stops working. If i toggle Wifi off it will work. Now I connected it to the office Wifi and its working fine.
I get one ring if i connect it to the house wifi..... its weird Any thoughts ?
Cheers
Ah, i got the same 2 exact phones as you, but i only have 1 number on one phone, but the reason i have 2 phones is because i like to switch at times. Anyway, are you primarily using e-sim? I mean, do you have 1 number on a physical sim, and another number on an e-sim? and are they the same numbers on both, or are they separate - technically speaking with a total of 4 phone numbers? Reason why I ask is because maybe it something to do with the cellular/e-sim settings on the phone?
Hi the problem is sorted… I had to get a networking professional to have it fixed… but it’s done
