RyanFlynn
521
476
Los Angeles
Hey friends,
I’m testing charging speeds on my new iPhone 17 Pro Max. With a 40W/60W charger and a Thunderbolt 4 cable, I’m only seeing ~25W. That works out to about 28% in 20 minutes instead of the advertised ~50%.
I’ll try again with the included cable once I drain back to 0% battery, but curious if anyone else is running into this.
So far, I see two possible issues:
  1. The Thunderbolt cable doesn’t actually support the full charging speed.
  2. I stressed the phone with benchmarks, so the battery/phone is too hot and throttling charging.
I’ll keep testing and report back, but would love to hear if anyone else is seeing similar numbers.
—Ryan
Ok, So I've tried 3 different cables, with a totally good phone from 0%. I'm only getting to 31% in 20 minutes.
Cables tried:
2 meter thunderbolt 4 cable.
1 meter thunderbolt 3 cable.
iPhone 17 pro max stock cable that was included in the box.
confirming that this is the charger I'm using:
My 17 Pro draws about 35W max when low on charge. The draw depends on battery level and time. 25W doesn't seem out of line.
There are several factors that affect max draw:
  • Battery Level: Peaks 0-50% (~3A); tapers after (~2A or less).
  • Temperature: Throttles above 35°C to ~2A (safety first—Apple's conservative).
  • Charger/Cable: Needs 40W+ PD (e.g., Anker/Samsung 45W) and e-marked USB-C cable (5A-rated). Cheap cables limit to ~2A.
  • No Overdraw Risk: PD negotiation prevents exceeding 3A (it'll supply up to 3A at requested voltage).
