Hello,
I am having a problem with my iPhone 3G 16 GB
I have connected it to AC charger for 10 hours... but the screen did not change.. which is red battery with bolt
I disassembled it.. tested the battery alone with voltmeter ... the reading was 3.99 Volts
but when I tested it while connected to the board .. it gave 1.3 Volts
Also, while it is connected the AC charger, i can turn it on by pressing sleep/wake button.. and it shows "connect to iTunes" screen.
when I diconnects it from AC charger to connect it to laptop.. the screen goes dark.
If I connect it to laptop... the red battery with bolt shows up.. but i cant turn it on (possibly because the current of laptop USB is much lower that AC charger).
Pls help
Thanks in advance
Pls help
Thanks in advance
