jgray106
4
Ok, I'm making my very first iPhone application (so bear with me... and sorry if there is heaps of information/explanation before I get to the problem, but I just want to make sure that you get the whole story)
I am making a quiz application and, considering there is over 400 questions and menus and stuff like that... I have spent weeks creating png files with the questions and menus etc... Ok, so in xcode I have added .h and .m files for every screen that I have made. Firstly I would like to know if I have made any mistakes with the code (I've never written code before...)
This is the code that is in each .h file (note that I did not actually put "name" in place of my name and did not put "nextscreen" in there, I just put that as an example):
// name.h
// name
// Created by name on date.
// Copyright 2010 __MyCompanyName__. All rights reserved.
#import <UIKit/UIKit.h>
@interface FilmViewController : UIViewController {
-(IBAction)nextscreen;
@end
This is the code that I have put in the .m files (same as above, I did not put in "name" and "nextscreen"):
// name.m
// name
#import "nextscreenViewController.h"
@implementation nextscreenViewController
- (IBAction)nextscreen;
nextscreenViewController *nextscreen = [[nextscreenViewController alloc] initWithNibName:nil bundle:nil];
[self presentModalViewController:nextscreen animated:NO];
**(after this, this is word for word what I have)**
// The designated initializer. Override if you create the controller programmatically and want to perform customization that is not appropriate for viewDidLoad.
- (id)initWithNibName:(NSString *)nibNameOrNil bundle:(NSBundle *)nibBundleOrNil {
if ((self = [super initWithNibName:nibNameOrNil bundle:nibBundleOrNil])) {
// Custom initialization
return self;
// Implement loadView to create a view hierarchy programmatically, without using a nib.
- (void)loadView {
// Implement viewDidLoad to do additional setup after loading the view, typically from a nib.
- (void)viewDidLoad {
[super viewDidLoad];
// Override to allow orientations other than the default portrait orientation.
- (BOOL)shouldAutorotateToInterfaceOrientation:(UIInterfaceOrientation)interfaceOrientation {
// Return YES for supported orientations
return (interfaceOrientation == UIInterfaceOrientationPortrait);
- (void)didReceiveMemoryWarning {
// Releases the view if it doesn't have a superview.
[super didReceiveMemoryWarning];
// Release any cached data, images, etc that aren't in use.
- (void)viewDidUnload {
[super viewDidUnload];
// Release any retained subviews of the main view.
// e.g. self.myOutlet = nil;
- (void)dealloc {
[super dealloc];
@end
Ok, so after I did that for all the screens, I created the .xib files from (User Interface --> Window XIB) and I named them all exactly the same thing as all the .h and .m files (for example if I named one DFE.h and DFE.m then I did DFE.xib)
I then tried to use Interface Builder to "link" the pages that I created. I double-clicked on the newly created xib files, placed in an image view, put in one of my png screens, then placed round rect buttons over the buttons that I need people to press to get to the next screen, changed the button type to custom, but now I can't see the "received actions" that I created in the .h and .m files. What am I doing wrong? Please help! :confused:
Please consider changing the thread name to something more useful. That way you might get better answers.
