cvest
29
It is my understanding that aftermarket lightning cables and AC adapters can have a negative affect on your iPhone's battery. I am going to attempt to avoid that with my iPhone 6s but started thinking about my prospective case, the Lifeproof Fre Power. Since it is using a Micro USB cable to a Lighting adapter built into the case I am concerned that maybe it could cause issues? I am not very knowledgable on this issue and I know there are many of you on here who are. Also does it matter which wall adapter I would use or does the case determine how much power it delivers?
Thanks
