Consider any MacBook laptop powered by a lithium ion battery. Assuming proper care / maintenance, if you leave it plugged into the wall while using it, the battery will last longer (i.e. you'll go through fewer charge cycles and won't need to replace it as often) than it would if you use it off charger and only plug it in when the battery runs low.
Is this behavior a property of lithium ion batteries themselves, or does it have more to do with a specific way laptop batteries are engineered?
For example, I have both an iPhone and a pair of headphones that use a lithium ion battery as well. Both devices can be charged via a USB port. Will these devices exhibit the same behavior as a MacBook in terms of battery longevity, or are they engineered differently?
Put another way, is battery wear and tear primarily a function of charge (i.e. 100%, 75%, 25%) or can electrons still move through the battery on a full charge, in such a way as to constitute usage of charge cycles (for example, maybe the rate at which the battery is charged is equal to the rate at which a battery is discharged)?
Anyway, I wasn't really sure exactly how to ask this, so hopefully you can make out what I'm trying to get at.
Thanks
Thanks
