Howard2k
macrumors 604
6,694
7,253
I’m guessing it’s not more than 433Mb/s for Wifi5? And for Wifi6?
Please post your speed and router if inclined. The MacOS connection info would be super.
thanks.
Does anyone with a MacBook Air use wifi? Or you guys are all connecting via Ethernet? :)
My MBA M1 connects to my wifi6 router with a Tx-Rate of 1.200Mbit/s.
Speedtests show around 850 Mbit/s.
When using my USB-C ethernet adapter (Anker 2.5Gb adapter), i get about 940 Mbit/s, which is close to the theoretical maximum in my 1Gb home network.
I'm also using a 1Gb internet connection.
Reactions: Howard2k
On my TP-Link AX-50 (Wifi 6), I've gotten as high as 240 Mbps both up and down, using our Fios service. I'm only paying for 200/200, so this is very much in line with what I'd expect. Tends to drop off a little at the other end of the apartment.
Reactions: Howard2k
When using my USB-C ethernet adapter (Anker 2.5Gb adapter), i get about 940 Mbit/s, which is close to the theoretical maximum in my 1GB home network.
Thanks!
Thanks. Please can you confirm the TX Rate (Opt-click the Wifi icon in the task bar). Ideally when you're close to the router but I'll take what I can get.
Screenshot would be super amazing too if possible.
Thanks!
Thanks!
This is a few rooms away from the router, which is where I'm at now:
Reactions: Howard2k
