Help, dj set in a few days!
I've been having problems with virtual dj 5.2 and rmx console. I only have sound coming from the left speaker and not the right. My speakers are wired fine as when I disconnect from the RMX console, the cd separate works fine.
When I cross fade the music from left to right deck on virtual dj, the music is only playing and mixing from my left external speakers?. Also, I plugged my headphones in channel 4 of the rmx console and the right deck is playing in my headphones but not the right speaker?
Confirguration:
Inputs: none
Outputs: headphones
soundcard: 4 out card
driver 1: heacules console RMX aggregate
Output channels: Master channel 1 & 2 headphones channel 3 &4
In system preferences, sound it says:
play sound effects through hercules rmx console
Output: hercules dj console RMX
Input: hercules dj rmx aggregate
In Applications, Utlities, audioMIDI setup:
Hercules DJ Console RMX (use this sound for output)
Configure speakers: Multi-channel Quadraphonic 1 , 2, 3, 4
Hercules DJ Console Rmx Aggregate (use this sound for input) Use Audio device In Out
4 in / 4 out box ticked Hercules DJ Console RMX 4 4
Configure Speakers: Quadraphobic, Multi channel 1, 2, 3, 4
I did notice that when testing sound in quadraphonic, no sound from my speaker right came out? only test sound came out of left speaker.
I've updated all the software such as drivers as I have snow leopard for macbook pro. 10.6.6
Help, djing in 5 days!
Confirguration:
Inputs: none
Outputs: headphones
