3rdPerson
4
My fan speed is constantly an annoyingly loud 6200rpm and my CPU temp is 84 degrees. That seems both too hot and too fast - no? Can anyone offer advice about what the ideal temperature and fan speeds should be -- and if it sounds like my laptop has an overheating problem?
Check with Activity monitor which process are using all the CPU.
Activity Monitor?
Thanks. I am looking at the Activity Monitor, however I don't know how to interpret this information...I am posting a screen-grab of the monitor in hopes that you can help me interpret.
All Processes
Okay - I've organized as "All Processes", and ranks by CPU from highest to lowest. There are 2 attachments to see the full list of all processes.
Can you see any problems?
Fixed!!
Wow - I quit out of the PrintJobMgr application that was hogging 97% of the CPU and the temperature and RPMs dropped immediately. Within 4 minutes, the fan speed dropped from 6000RPMs to 1800RPMs, and temp is down to 50 degrees.
Thank you guys so much for the advice!
(Is 50 Degrees okay for the CPU?)
