Love-hate 🍏 relationship
macrumors 68040
3,954
4,637
the MBA m1 ships with a 20w power adapter , although it seems it can charge faster than that,up to 45w or sth (given the mbp M1 does have a faster charger )
has any of you tried that?
does it truly speed your charging up?
is there any risk at doing this ?
I'm pretty certain it would charge faster, although I never tried it.
And if you are using a good "standard-compliant" charger, there is no risk. (Modern USB chargers don't just send a fixed amount of power. When you plug in the device it actually start charging at a low standard charging speed instantly (5W I believe), then the charger and the device communicate which charging mode they support, and they activate the fastest one that they both support.)
