Hello everyone;
I needed extra battery life on the go so I purchased one for my Santa Rosa MBP. Unfortuantely, it was faulty and got "stuck" on the laptop, meaning you can't remove it easily (and as of today, you can't remove it at all). I had to use my nails.
It was also too late to return because I was on a way to an international trip.
Today, while I was trying to remove the battery I peeled the casing off and its stuck on the laptop for good. Would this cause a problem when I try return the battery? I am absolutely sure its not a problem with the laptop itself because I can remove my old battery without any problem.
Thanks in advance.
Thanks in advance.
