I've been having trouble for the past month with my MBP charging. I was at a coffee shop for several hours with the laptop plugged in and didn't have any trouble. I did a software update for the laptop and my iPhone, but I don't think it was anything pertinent to power. If I remember correctly, it was Safari and some other small update. Anyway, when I went home I plugged it in again later that evening, since I needed to charge my phone again. From what I can recall, it was charging, but when I woke up it had stopped charging and the battery had died. I tried cleaning the connection and also plugged it into a different outlet. Eventually it started charging again, but only long enough to give me 30 minutes of battery charge. It may have stopped charging when I plugged my phone in again, I didn't notice right away.
I tried resetting the PRAM and that didn't help. It was a week before I was able to take it to the Apple store. However, when I took it in, it charged without a problem. We also tested my adapter and that worked fine in my machine and in one at the store. There also didn't seem to be a problem with my iPhone, that they could tell.
I took it home and was able to charge it again. However, a couple days ago I went back to the coffee shop and as soon as I plugged it in it stopped charging. I had things to do, so I just let the battery die. When I got back home I tried charging it again and it worked.
I haven't plugged in my phone since the problem started, or anything else, so it's not a problem with USB. My battery has had "service" status for several months, but when we went to the Apple store they checked it and it was at 80%, so it's low but not very low. Every time the battery dies the PRAM settings are reset. The only thing that has been consistent in the instances when it stops charging (other than the first time) is that I changed the date/time settings back to automatically detect (I don't have Internet access at home so I have been setting it manually until I go online). If that's the case, it sounds like a problem with the PRAM, but I don't know if that's just a coincidence. So far I haven't put it back to automatic and I haven't had any trouble with being able to charge, and it's been a couple days. However, I don't want to spend $40 on a new PRAM battery if it's really a power problem.
Any advice on what it could be or other tests I can do?
Intel Core 2 Duo
2.2 GHz processor
Snow Leopard 10.6.7
Intel Core 2 Duo
2.2 GHz processor
Snow Leopard 10.6.7
