I discovered that my late-2013 MBP has a swollen battery; I didn't notice it for a (long) while because I use it primarily in clamshell mode - a cautionary tale. It still works, but the trackpad only works if you press one spot, and computer doesn't sit flat. Fortunately, I have both Backblaze and Time Machines backups, so I'm not concerned about having lost data. Even more fortunately, I had just picked up a new 2020 13" MBP as replacement, so I want to just erase the SSD on the old computer and recycle it at the local Apple store.
My question is this: If I use Migration Assistant to transfer from my Time Machine drive just the "User" folder only (not "Applications", "Other files and folders" or "Computer and Network Settings", which are the other options), will that transfer the Documents, Desktop, Movies, Music and Pictures folders from my old computer? Those really are the only folders I care about. Does anyone know what the "Other files and folders" option covers? Applications I will reload; any computer and network settings I need came over when I used my Apple ID to set up the new computer.
Because my old computer had years of old files, bloat, etc, I had planned to manually delete a bunch of old stuff and just transfer over what I wanted, but I want to use the old computer as little as possible given its condition. I'll have to do the cleanup on the new computer, but want to transfer over as little as possible beyond the documents, photos and movies I care about.
Many thanks in advance!
