ahollywoodcraig
55
Hi. I hope someone can help me with this.
I have been trying to burn an Mpeg file to a dvd using Toast 7. The dvd comes out fine and plays well on my standard dvd player. The problem I'm having is that about ten minutes into the movie the audio gets off. This has happened twice with two different movies. The Mpeg file itself when played in Quicktime has no audio issues and plays fine all the way through. Does anyone know what is causing this? If you could help me understand what Is wrong I would appreciate it very much. Also if no one knows are there any alternatives to Toast that I can use to burn mpegs to dvd?
Thank you in advance,
Craig
i don't know.
I don't there is another app that will do what you want. iDVD maybe ?
Anyway, maybe try saving your DVD as a disc image and letting it encode that way. Then burn the resulting disc image in the "copy" tab in Toast.
Different method for the same result, maybe it will fix it?
I'm sorry, but I'm an idiot when it comes to this stuff. How do i do that? I did try iDvd last night and it doesn't work either.
