wiljowibo
Hi,
i need to know the pin outs on the iphone 4 logic board. my iphone will work only off the charger and not the battery.
the battery is fine.
i had a repair done on the connector as it came off. now its all working apart from on the battery so just trying to work out which of the 4 connectors could be causing the issue....
Cheers
I did a Google search for the pinout of Apple's 30 pin connector and easily enough found what you were looking for so I recommend you do the same.
