sdfd504
237
11
Soddy Daisy, TN
Well I made the idiot move of dropping my MacBook pro tonight out of my truck. It was in a Tom bihn case which is pretty sturdy but now the screen won't come on. What all do you think is broke in it. I know the hard drive seems ok since I can still type the wrong password in and it makes the Noise for that. Not sure if the logic board went bad or if it is the actual screen?
If everything else works but there is no image, good chance that the cable for the screen might be damaged which would be a cheaper repair vs. logic board.
