Arg.
My university is using some fancy new wireless authentication.
It can take me up to 4 hours to get an ip.
However, If I spend 10 minutes turning off airport, then reconnecting, it will usually obtain an address.
I'm not sure how I'd do this in apple script or a shell script...
Basically what I want to have happen is this:
connect to a specified ESSID
wait 10 seconds
check my ip with IFconfig every 5 seconds for 45 seconds to see if I pull in an ip that doesn't start with 169
If I pull down an ip that is not self-assigned close the script, else disconnect then repeat ad infinitum...
I'm not sure i can do all of this in a bash script... but this is what I've got...
i know it doesn't do anything...
#!/bin/bash
# Setup and variables
AIRPORT_BIN="/System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Resources/airport"
MY_ESSID="EXAMPLE"
IF_BIN="/sbin/ifconfig"
IFACE="en1"
# script
# I need some conditional statements here, I'm sure how to do it...
# basically if my ip starta with 169 I know its self assigned... unless there is a more efficient way of finding this out
# to get my IP i figured I;d use this
ifconfig $IFACE | grep "inet " | cut -d\ -f2
# disconnect from airport
$AIRPORT_BIN -z
# I know I don't need this, it's just laggy
sleep 15
# Reconnect
$AIRPORT_BIN --associate=$MY_ESSID
# wait 45 seconds to see if it pulls in a proper ip
sleep 45
I know its not much....
but any help would be greatly appreciated...
wait 10 seconds
#!/bin/bash
MY_ESSID="EXAMPLE"
IFACE="en1"
# script
$AIRPORT_BIN -z
sleep 15
# Reconnect
sleep 45
