Asu
69
7
Hello Mavens,
I need help (as in "Pretty please tell me exactly how to do it...") with the following task.
Code:
while running in the background
(at random intervals (between 0.5 and 5 minutes)) (do a command)
that's it!
TIA and Merry (OS)Xmas
Asu
Code:
until [ 1 -eq 2 ]
do
  let "sleepval = $RANDOM % 271 + 30"
  sleep $sleepval
done
No guarantees, this was written on my phone. The principle should be clear, though. In ...'s place you put what you want to run, then get a random value from 0 to 270, then add 30. This is the amount of time in seconds to sleep.
There is quite likely a better way, but I think this should work.
-Lee
