After my previous router dying in a dramatic puff of smoke, I decided to buy the just released Airport Extreme N router and a Netgear DM111P Ethernet ADSL modem. This is to replace my previous Wireless Adsl Modem router which was basically an all in one.
The airport itself sets up great, the modem just doesn't want to join in.
The modem is plugged into the WAN port and works correctly when I plug just one computer into it. However, it will not be correctly detected with the Airport.
I have tried setting the airport to 'Connect using Ethernet' and use DHCP as i noticed the modem likes to like at 192.168.0.1
When I press update and the page refreshes to the updated changes, the ip address and DNS servers set themselves to some random ip address usually beginning with 247. or 194. (my BT broadband outside ip address usually begin with 86.) and the internet does not work.
Edit: Forgot to add that BT broadband uses PPPoA annoyingly instead of PPPoE
Any ideas much appreciated as my brother and sister are yelling at me for not being able to fix it
