dslrjunky
211
65
as the title says, anybody here have the same case for Iphone 12 pro max that have a squeeking sound when pressing on either side (front lip sides too) of the case even just pressing it lightly?? I got the case on sale (bestbuy) and was wondering if any of you having the same issue, I might exchange it but wanted to ask here first.
If you have tried to remove the silicone outer layer and the polycarbonate two piece frame, try to reassemble it again paying particular attention when making sure that all frame clips are secure. If this doesn't work, call Otterbox customer service who will request a number off the case so that they can send a replacement. I have no issues with my Defender case which I ordered off their website.
on the bottom part of the case I actually have a visble gap, I thought maybe it was the tempered glass, but it's not even touching the edges of the case and the gap is only on the bottom part of the case and the bottom half is where it makes the squeeking sound
