l0renz
289
9
Hi
My iPhone 4S warns me 5-10 minutes after the boot 'the iPhone needs to cool down before you can use it.'
The battery is not the cause because I get it with multiple batteries, all original.
The attachment included shows you which part of the iPhone heats up (basically the logic board?), the normal colored area is the area that heats up.
Is there any particular hardware part that is known to overheat the iPhone (logic board)? Excluded from the battery itself...
Best regards
Lorenz
