Yep, that would work fine. It's a 150W rating, and your computer is a max of 60W, so it will be plenty
thanks..
there won't be any problems "overpowering" the MBP, so to speak?
also, the functionality where the MBP doesn't draw any power once fully-charged will work with said charger, correct?
thanks..
Nope. The adapter will only draw as much power as it's rated for. Can't be overpowered.
