Hello
I have a 2010 Mac Pro 5.1 that is running Monterey using OpenCore. Been working very happily for at least the last 6 months, nothing has been changed on the system. Recently it has been shutting down suddenly. It shuts down and then won't reboot, power button unresponsive. Then later, maybe the next day, it will power on again and run for a while before just shutting down again.
I bought a replacement Power Supply and fitted it. It worked for a couple days then same thing, it just shuts down
I replaced the CPU tray with a known working CPU and same problem
I have removed all drives and same problem
I have followed the 'tech service manual' of breaking down the machine to Minimum Configuration but that didn't really answer anything
If anyone has any suggestions that would be great, thank you
