scott:mac
186
Great Britain
I opened up my mac mini to upgrade some RAM.
I looked at it, didnt know what to do so i closed it.
When i came to switch it on.
The white light comes on, But the rest of the system sounds responsless.
And then after 5 seconds, it will cut out.
:// what have i done?
did you properly ground yourself while touching the components inside your mac? ... I presume you just 'looked' at the electronics inside and did not take anything apart right?? If you did remove your RAM and put it back, then prolly you did not place it back properly ... check that
