Does leaving a MacBook Pro permanently connected to a power supply damage the battery and reduce its life? Or is the equipment smart enough to prevent this?
No, but leaving the power supply plugged in when you're not using it will shorten its life; if its generating heat, its working hard for no benefit.
It won't shorten it's life much. All you need to do is use it from battery once every few weeks. Heat will always shorten its life a little whether it's plugged in or not.
