Does anybody else have problems with the functioning of the mini display port of the new MBP? When at home I usually run it with the lid closed, a 24 inch external LCD attached. However the external display connection drops at unforeseeable time intervals and the simplest way to resurrect the connection I found (after rebooting the first few times it happened) is unplug and replug the display port to DVI adapter on the MBP side.
I never had any problems of this sort with my previous generation MBP and the same monitor (which was then attached directly to the DVI connection of the MBP.)
