nachoezq
Hello! I bought my mac less than a month ago and felt like my battery was too weak. I found this app to check my battery status and found it to be 91% ... very strange. Do you think I should contact Apple? or wait to see if it stabilizes? any advice?
Thank you!
Apple will not entertain your "battery problem" as long as it is more than 80%. You can try turning off battery health management and monitor it again for next few days and share your finding.
What's the health percentage of the battery in your car? You don't know. The only reason you ask about your computer battery is because there is number you can see. Don't worry about it. It's not a reliable number. It's not supposed to be watched. If you have real battery "problems" Apple can use that number to figure out whether you qualify for a warranty replacement. But don't try to read something into the number that isn't there.
