StressedSnowCat
47
Hi,
I'm designing some envelopes for my newly created business and I'm kinda desperate, I can't see to be able to set the top document margin lower than 6.96cm. If anyone has a fix I'd really appreciate it!
I'm working on a European Sized Envelope (110x220cm) and non printable area is set to 0mm. What could I be doing wrong?
Thanks in advance!
i was having the same problem...
am i safe in assuming that you're on the new, free version of pages? if so, you can adjust the margins either by dragging the little arrow on the ruler (but that won't let you lower it below a certin point) or you can change it in the "document" pane of the "setup" inspector.
the attached picture shows where you should be able to lower it. setup>document>document margins
