loztheguru
86
i recently bought a usb 2.0 hub as i was fed up with having to swap all my stuff around, especially as my MacBook only has 2 ports. Anyway, ever since i began using my mouse has been acting up, jumping all over the place and brining up dashboard/expose with me clicking anything. Its on its own usb port, not plugged into the hub, so i thought it should be fine. Anyone got any ideas as to how I can remedy the situation? I really need the hub as im using an external HDD and a usb mouse, so Id have to remove one or the other to use a card reader/ipod etc. The hub is powered if that makes any difference...
its never happened before, and ive had the hub a day or so and the problems are frequent so im fairly sure that the hub is the cause.
okay, tried it without teh hub for the last couple of hours and no problems. Plugged it back in and within five minutes the cursor was twitching and my hotkeys were going crazy, so looks like its definitely the hub thats the problem.
the mouse was originally in the hub but i moved it out as i thoguht that might be the cause of the problems
It is a powered hub and i ahve hte cable plugged in at all times, however when i tried to plug my kingston usb data stick in it said that i was drawing too much power from the port and should unplug other devices. All i was running off it a the time was my HDD which has its own power supply anyway, so im a little mystified.
