bjelder
31
So I was playing with my ipod today and all of a sudden half the applications won't load....
I click them, the little 'intro' screen comes up, then boom back to the home page
Whats the deal :confused::confused::confused:
1. Try resetting your iPod to start it off. Press and hold both the SLEEP and the HOME buttons for about 10 seconds. The "Slide To Power Off" option will appear, but keep holding the buttons.
2. If the apps still won't work, try ACTUALLY turning off the iPod by holding the Sleep button for about 5 seconds until prompted to "Slide To Power Off" your iPod. I've actually managed to get some things to work after restarting it, rather than resetting it.
3. If those two are unsuccessful, re-sync all your apps (although you might lose the data you have for those apps)
4. And you last resort: restore it via iTunes.
Yeah, reboot your phone.(What is this Windows!) :( Unfortunately the iTouch OS is not that stable yet so it's a good idea to give her a kick in the butt(reboot) every now and then.
