Hi all,
I have an issue with the LG 27UD88 monitor that pops up intermittently and was hoping to get some help.
Some context:
The issue:
Thanks,
Jun180
Some context:
- This monitor is USB-C enabled, so it’s just a single USB-C cable plugged into the USB-C to my 13” 2016 NTB Macbook Pro to provide video signal to the display and charging for my laptop.
- I have my laptop constantly plugged into the monitor running in clamshell mode.
- I have a Bluetooth keyboard and mouse, and usually clicking either one of these will wake my laptop and also fire up the monitor, which will then display the login screen.
The issue:
- The issue occurs when waking the laptop from sleep. I use the Bluetooth keyboard or mouse to wake the laptop, but there is no response from the monitor and it is still in standby mode.
- If I open the laptops internal display, I can see the screen has turned on but is showing a black background and the mouse icon only, but no response from OSX to any other inputs.
- If I try and disconnect USB-C cable, the internal screen on the laptop seems to adjust its resolution, but still displays a black screen and no response from OSX.
- This issue occurs in Sierra, and High Sierra.
Thanks,
Jun180
