thousandisland
Hello people,
Issue occurred when I charged my MBP (uni-body, 2nd latest gen) and it was 100%. I plugged out the cable not wanting to damage my battery and the moment I did so, the MBP "crashed" and shut down for the first time in 10months.
I had to power it up again and when it was loaded, the date/time was resetted to 2001.
Weird thing is the, battery condition now is 'Condition: Replace now'
I checked my coconut battery and statistics (full charge capacity) for my battery is still healthy. From system preferences,
Battery Information:
Model Information:
Serial Number: 9G002080C8VPC
Manufacturer: DP
Device name: bq20z451
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0003
Hardware Revision: 0002
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 4355
Fully charged: No
Charging: No
Full charge capacity (mAh): 5016
Health Information:
Cycle count: 250
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): -1361
Voltage (mV): 11978
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Display Sleep Uses Dim: Yes
Battery Power:
Display Sleep Timer (Minutes): 5
Current Power Source: Yes
Display Sleep Uses Dim: No
Reduce Brightness: No
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: No
Charging: No
Question - Should I just ignore the 'Condition: Replace now' prompt at my battery option?
Anyone has experienced such an issue before?
