Taylor C
729
I've had my 20" Cinema Display for awhile now, and have come across an issue that is concerning me with the DVI connection. This isn't an issue present during normal use, but if the DVI cable is moved right or left (fairly severely), the entire image gets a purple overcast. Returning the DVI cable to it's normal position fixes the issue.
Is this something that I should be concerned about? It seems a bit odd, and I'm not exactly sure how I would go about fixing it since the cable isn't easily replaceable if it is.
