MacRumors
macrumors bot
70,494
42,194
Last month, Mophie announced the launch of its Max Charging Stand. Aimed squarely at those with multiple sets of Apple's headphones, it can charge AirPods Max headphones plus a pair of AirPods or AirPods Pro at the same time.
Priced at $150, it immediately garnered criticism in our forum, largely over its price point compared to its functionality. But is it actually worth it? I've spent a few weeks with it to see.
Design and Build
The charging base is aluminum lined with smooth silicone along every surface that comes into contact with your devices. The bottom also has a large rectangular pad of this same silicone so that it doesn't slide easily on your desk. The Mophie logo is subtly stamped on the top just under the square indentation that shows you where to place your AirPods (or other Qi-enabled device) for charging.
At 15.7 ounces (445 g) on my kitchen scale, it's weighty enough to hold my AirPods Max without wobbling. But more on this later...
It comes with a decently long 5-foot USB-C cable coated with the same silicone that covers the stand, a 20W wall adapter, two magnetic charging dongles, and a pass-through adapter.
To use the stand, you insert one of the magnetic dongles into the USB-C port of the AirPods Max. This dongle then connects automatically to the charging port in the stand thanks to its magnetism. The second magnetic dongle included is a spare which is a nice touch, especially at this price point.
The pass-through adapter allows you to leave a charging dongle in the Max's charging port at all times so you can still charge it with a standard USB-C cable, avoiding wear and tear on the port with frequent removals and insertions. But on the other hand, this is another adapter to carry around and avoid losing. The pro tip here is to just leave this dongle attached to a USB-C cable you use to charge the headphones when you're away from home.
Using the included pass-through adapter to a USB-C cable
The charging dongle does not pass through audio, so if you use your AirPods Max with a cable for lossless audio or to connect to a 3.5mm analog device, you'll have to remove the dongle each time.
The magnetic dongle is the key feature of the stand and it isn't a new concept—charging stands that make use of a magnetic dongle have been released by smaller companies over the years (e.g., the Max Stand a few years ago) and Mophie's is a premium entry by one of the larger Apple accessory makers.
How It Works
When you place the AirPods Max on the stand, the white LED on the front of the stand illuminates for a few seconds and then turns off. Since you can't see the status light next to the USB-C port on the headphones themselves to verify charging while it's in the stand, it's a bit frustrating to not be able to see charging status after the stand's light turns off.
Additionally, since the stand places the headphones in sleep mode using magnets built into the ear cup holders, you can't even see its charge level on another Apple device in Control Center or the Battery widget unless you remove it from the stand. I'd rather this light stay on or pulse while the headphones are charging.
Removing the AirPods Max requires two hands since the stand, while weighing in at nearly a pound, is not heavy enough to overcome the magnetic force from the charging dongle. You must also use two hands to place the headphones into the stand since the ear cup holders are placed far enough apart that you need to stretch the headband wider.
This ear cup holder placement does, however, allow the stand to accommodate AirPods or another Qi-enabled device in the center. I'd been using a simple 3D-printed AirPods Max stand with no charging capability where the ear cup holders are close enough together that it's easy to drop in and remove the AirPods Max with one hand, so this was an adjustment for me.
The center charger fits an AirPods Pro case easily and the indentation makes it easy to target where it should go. It's even large enough to accommodate the large case cover I use on mine. It also charged my iPhone 17 Pro although it takes a few seconds to line it up in the right spot.
The center charger is nice to have but seems like an addition meant to add value to the stand to justify the price. I'd like to see a version at a lower price point without this center charger that would also allow a narrower placement of the holders for the ear cups.
Next to my (non-charging) 3D-printed stand
In my charging tests, I saw no significant differences between charging my AirPods Max directly with Apple's USB-C cable to a 20W wall adapter, using the Max Stand, or using the USB-C cable with the pass-through adapter that Mophie includes. Apple states that a 5-minute charge adds 1.5 hours of listening but does not claim any fast-charging features beyond this, nor does Apple specifically recommend using a high-wattage wall adapter.
Per iFixit, the USB-C AirPods Max has the same battery cells as the original model released in 2020 with a total capacity of 664 mAh. AirPods Max automatically limits the amount of power drawn during charging and using a higher-wattage wall adapter doesn't increase charging speeds.
With this stand on my desk, I noticed that I was no longer ultra-careful about taking every opportunity to put my headphones into sleep mode to avoid draining the battery. I started leaving my AirPods Max around the house willy-nilly without a charging care in the world since I knew I could easily pop them on the stand for a quick charge anytime. Using a USB-C cable to charge them is not hard of course, but it takes more steps than just dropping the headphones into a stand.
The Big Question
Will Mophie offer a Lightning dongle that will allow the stand to work with older AirPods Max models that have Lightn... Click here to read rest of article
Article Link: Review: Mophie's Max Charging Stand for AirPods Max is Pricey but Good
  • Haha
Reactions: AdamHarbour
Just get the Max stand by floating pixels. I got it cheaper when it was a kickstarter project, but for $99 it’s cheaper, has lightning and USB-C connectors, and looks nicer IMO
This is crazy. $150 and it isn't even substantial enough to stay on the desk if you take your headphones out with one hand? Anyone who buys this is getting taken for a ride.
Reactions: dustin_
If you want to ... make sure, you ... unless you have ... then add ... without plugging it in, control ... until ...
Do not forget to ... in case you are ...
I usually do not judge products at first sight, but this thing looks really ugly and complicated. It kind of reminds me of that bra thing, you get with the AirPods Max.
Reactions: dustin_
They made it pricey but good in order to match the whole vibe of the AirPod Max. It’s practically their motto.
Also got this off kickstarter. It could definitely have improvements like a status light and be slightly easier to connect. E.g. white = power connected, yellow=charging and connected, green = charged and connected. It is weird none of these companies have done this.
My APM have broken but I just checked and you can buy replacement magnetic things so I can upgrade to the APM with USB C. Hell yeah. I am glad I put my money towards this project.
Reactions: yanksfan114
Looks like a good charger. Won’t be buying one as I don’t use over the head earphones/headphones. Price is also high.
Reactions: mganu
In Poland, where I live, Apple doesn't sell AppleCare for headphones. There's only a one-year warranty. After the warranty expires, you have to pay about $420 for a replacement.
That really stinks, I’m sorry. I recall in my retail days that there were many more countries that didn’t have AC+ offered yet. My guess is it has to do with legal reasons and local/national laws.
