Hello, I recently came about a problem on my macbook, and I'm not really sure if this is a macbook only problem, But I have not found anything pertaining to it on the internet.
I've been using a little guitar-USB cable Called "Lightsnake," testing it out with garageband first, also looking at a few amp modeling systems.
The problem I'm having is that It was working fine for a while, but now emits this incredible static and barely picks up the actual input. I've tried it in a few different programs including Garageband and Audacity.
Thinking it was the cable, I picked up another. Same problem.
Then, thinking it was the guitar I was using, I tried using my other guitar and a bass hooked up to it. Same problem.
Also, I have soundflower installed on my computer if that makes any difference, and my inputs are having duplicates show up as "aggregated" inputs. I have no clue where to start on resolving this one. Help would be apreciated, thank you.
