shearm
87
16
Hey. anyone else having this problem?
when i plug the phone into the audio system in my mini cooper, i can play music, but the maps programs (apple, google) don't produce any sound at all.
Working just fine on mine. It was the first thing I tested when I updated yesterday. Are you running USB or AUX? If USB, the firmware on the deck may not be compatible, that you can't fix. But if AUX, unless something is wrong with your headphone port, no idea why it wouldn't work.
I have a cable for the minicooper that plugs into the phone and splits into two -- one usb and one headphone jack. those plug into the car just under the shifter.
in ios 6 (and some earlier ios7 betas), the map programs would use the speakers of the car, muting the music to announce a turn or whatever.
now, the map programs work just fine, there's just no sound that comes out.
but oddly, i can play music just fine.
Hopefully it's something that will get fixed with the master release. I'm not sure what would be inhibiting it though.
yeah. ive got my finger's crossed. thanks for the replies.
