Hi everyone,
I have mba air 14 early, and this post may look like I'm in tears but in fact I am. I have mba since December 2014 so it is 3 years nearly. Around august battery in mba just broke - that's what I supposed at the time). MacBook only runs when is plugged to power adapter. After removing the power adapter it suddenly shuts down. Today I called apple authorized service, in which I was told that replacing the battery will cost around 50$ and battery itself around 210$ and the told me that it could be also a motherboard, so I kindly disconnected and removed it from my brain. I'm thinking what to do in that situation. I paste system raport from my mba, maybe somebody will know how to analyze this. It is in polish, but I think positions are the same in both languages
What should I do in this situation? I'm not sick to pay 260$ for battery, and I'm almost decided to buy battery from eBay or something like this hpingthat it will be good
Ps: When I click on battery on status bar it says condition: normal.
Informacje o modelu:
Numer seryjny:
Producent: DP
Nazwa urządzenia: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Wersja oprogramowania sprzętowego: 511
Wydanie sprzętu: 000a
Wydanie baterii: 1200
Informacje o naładowaniu:
Pozostały ładunek (mAh): 5844
Całkowicie naładowana: Nie
Ładowanie: Nie
Pełna pojemność nominalna (mAh): 5844
Informacje o stanie:
Liczba cykli: 406
Stan: Normalny
Baterie zainstalowane: Tak
Natężenie (mA): 0
Napięcie (mV): 8580
Ustawienia zasilania systemu:
Zasilanie prądem:
Zegar usypiania systemu (minuty): 1
Zegar usypiania dysku (minuty): 10
Zegar usypiania monitora (minuty): 10
Budzenie po zmianie zasilania: Nie
Budzenie po otwarciu pokrywy: Tak
Budzenie przy aktywności LAN: Nie
AutoPowerOff Delay: 28800
AutoPowerOff Enabled: 0
Bieżące źródło zasilania: Tak
DarkWakeBackgroundTasks: 1
Monitor wyszarzony podczas uśpienia: Tak
GPUSwitch: 2
Hibernate Mode: 3
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 10800
Standby Enabled: 1
Zasilanie z baterii:
Zegar usypiania systemu (minuty): 5
Zegar usypiania monitora (minuty): 5
DarkWakeBackgroundTasks: 0
GPUSwitch: 2
Hibernate Mode: 3
Redukcja jasności: Tak
Standby Enabled: 1
Konfiguracja sprzętu:
Zainstalowany UPS: Nie
Informacje o zasilaczu AC:
Podłączony: Tak
Moc w watach (W): 45
Rodzina: 0x00ba
Numer seryjny: 0x00247ad9
Ładowanie: Nie
Numer seryjny:
Producent: DP
Pack Lot Code: 0
PCB Lot Code: 0
Ładowanie: Nie
Liczba cykli: 406
Stan: Normalny
Natężenie (mA): 0
Napięcie (mV): 8580
Zasilanie prądem:
GPUSwitch: 2
Hibernate Mode: 3
Standby Enabled: 1
GPUSwitch: 2
Hibernate Mode: 3
Standby Enabled: 1
Podłączony: Tak
Rodzina: 0x00ba
Ładowanie: Nie
