Hi all,
I am having a major problem with my 24inch aluminium (2.44ghz mid 2007 running leopard 10.5.8) superdrive
My apple care warranty has expired, the original superdrive died sometime last year and it took me a while to get it replaced. I took it down to a local apple care shop and paid for it to be looked at, buy a new superdrive, be replaced and labour costs, all up was NZD $650.
I received it back within 2 weeks and the new superdrive (manufactured in 2010, made in Malaysia) was working fine, it was reading, recording etc.
BUT 5 months later I decide to start backing up all my university work, I burnt about 20 dual layer dvd's at that time, while I waited for the burning process to finish I was multitasking by either watching online tv shows or playing music. My imac started to freeze, I had no control over it except to hold down the power button to restart it. I just thought my multi tasking was the reason for this so I continued on burning more dvds without doing so much other stuff in the background. THEN it happened again, the imac was frozen. I couldn't do anything except to restart it.
After a while without burning, just general internet use the superdrive starts to make ejecting noises, with absolutely no discs in it. It then starts to make ejection noises non stop like 3-5 split seconds one after the other, I restarted my imac, it logs in well, with no programs running and what do you know, no noise at all. So I thought maybe the restart had helped it. BUT BOY WAS I WRONG! After 5-10mins later it starts making the same ejection noise still with no discs in it, I even inserted a disc to see if it would work and to my surprise it read the discs I had just burned with no problems at all, but soon after I ejected the disc, it starts to make that same ejecting noise. The disc drive even shows up on disk utility, I thought maybe it had some sort of sensor error (i.e it thinks there's a disc in it so it tries to constantly keep eject one out), I unplugged my keyboard thinking that I had a sticky key but still no luck.
I started doing a lot of forum searching around the internet to see if anyone else had the same or similar problem but I couldn't find anyone out there that had the exact or similar problem as me. I did all the resetting of the PUM, PRAM, SMC etc... you name it, but nothing helped! I even mounted my installation CD and reformatted my whole operating system, after a whole lot of unplugging, restarting, updating etc... the noise still came back shortly after. A couple of days later I called up Apple support team to see if they could help me, and since I don't have apple care any more she asks if I want to pay $70 for her to help me over the phone or just send it back down to the apple shop and get them to have a look at it again. While I was deciding she suggests I send it to the apple shop any way because my problem seems to be something she cannot help me with over the phone.
I then rang the Apple shop who fixed my drive and explain my problem to one of their tech guy, he then tells me I'll have to drop it back off and pay them to look at it by the sounds of it I'll have to get the superdrive replaced again, and what do you know, I'll have to pay the same amount again because the part only had a 3 MONTH WARRANTY!!!!
I was then on the hunt to look for a superdrive online so I could just replace it myself, I have experience in openinh up my imac when my harddrive failed on me earlier last year which I replaced with a 1T harddrive that works perfectly fine. So I came across this one online from someone who also had a failing superdrive:
http://www.dvwarehouse.com/DVD-R-/CD-RW-8X-SuperDrive-for-intel-base-2006--2007-p-36069.html
I waited no more and paid NZD$160 including shipping fee, the item arrived within days because I paid extra $ for a higher priority shipping time. On it, it says manufactured in 2007, made in Malaysia. Although there were a few dents on the aluminium case along with a few curious bends which I didn't think such exterior would effect the interior at all.
I opened my imac and replaced the superdrive, screwed everything back up and turn it on and it doesn't work, ABSOLUTELY NO POWER RUNNING THROUGH IT AT ALL! It doesn't even show up on disk utility! So I reinstalled my old superdrive back in to see if I was doing anything wrong or could have missed a step in the process... The power ran through my old superdrive just fine.
So I start to get really upset because I felt like someone had stolen heaps of money from me
. I was angry at the dodgy website by sending me a dead/broken superdrive, be very aware of this site because it is very cheeky! For me to send it back to them they required a 25% restocking fee from me plus pay a lot for shipping it to them and have it reshipped back to me. And because of the dodgy aluminium cover, at my desperate and thoughtless times I thought that MAYBE it was effecting for it to not power up so I took off my old superdrive cover and swapped it around but that was not the case, there was a sticker around the screws of the cover for returning policies that I had ripped off in the process so I would of lost the chance of sending it back to them anyways
I then find this one on ebay: http://www.ebay.com/itm/18063064461...NX:IT&_trksid=p3984.m1439.l2649#ht_572wt_1270
NZD$90, asked VERY specific questions to see if this will work on my imac, the seller says Yes, so I buy it and within a week with FREE shipping from Taiwan the package arrives. I come across my observation and see that this one is slightly different, it came with a thin black plastic bit on top of the slot opening, it had a button like the ones you see on a PC where you press to eject a disc out, I was able to carefully removing that extra bit so I could screw the actual holder that is meant to be around it. It fitted well.
I started up the imac praying that it would work and what do you know... the same problem! AGAIN, WITH NO POWER RUNNING THROUGH IT AT ALL! The manufactured date on this one is 2008 made in Philippine.
Now I am left with 3 non working superdrives
Could I really have had bad luck in receiving two dead superdrives? Does anyone seriously know what is happening? Why is there no power running through the superdrives I bought from online? Do I need to install certain drivers for it to power up? I've updated everything I possibly can. Is there something I am doing wrong?
I have made sure a million times that everything is plugged in correctly and securely. I really don't know what else I can do, I am running out of ideas! I most certainly do not want to pay another $650 to Apple people just so they can replace it!
Please, if anyone has any ideas it would be much appreciated
