I myself have had this same problem...and i hated it! But, i believe i just figured out a way to quick solve this...
When you are in edit view and the effects are are on, simply press comman-shift-4 to use the screen shot "custom selector" and fit it to your image and it will save perfectly on your desktop, effects and all
Hope it helps!
Hope it helps!
