Hi,
I am not sure if the Anker 25600mah battery(15watts IIRC) or RAVPower USB-C Power Bank 26800mAh PD Portable Charger(30watts) messed with my Macbook 12" battery. I got a new one from Apple and it has been working fine but I would like to avoid a repeat on my Macbook 13" 2019 2.8ghz.
Would it be safe to top up the MBP 2019 battery during light usage using the Ravpower Power Bank 26800mAh PD Portable Charger since it is only 30watts whereas Macbook Pro charger is 61 watts.
I am waiting to get the Sanho 27,000mAh HyperJuice USB Type-C Power Delivery 3.0 Battery (Space Gray)
but hoping my Ravpower can work for a while more.
Please let me know if you charge your macbook via battery and if you ever had problems?
Thanks.
Thanks.
