aturshah
3
Anyone has reviewed Viewsonic VX2450WM-LED external monitor for Mac Pro 13" (new model)? Thanks
After research for few days, VX2450WM-LED fits my requirements and reviews are good. But I don't know whether it works fine with Mac Pro 13" new model. Most of reviews online are for monitor itself and not its compatibility with Mac.
It has DVI-D connector which should work with Mini DisplayPort to DVI Adapter. Any hands on review comments will help.
In general, any display should work fine with your MBP so long as you have the proper adapters. There have been some isolated issues with certain displays, but monitors are typically a plug-and-play type of deal. Hopefully someone who has actually used this model will chime in, but if compatibility is your only concern, you should be okay.
Personally, I haven't reviewed this monitor myself but I don't see a reason why it would not work with proper adapter...
