AlvinDj
22
As of title ?
Anyone knows ? Because apparently my 3GS's back is being protected by BodyGuardz and it's way too tight to fit the MiLi Power Pack external battery.
I know there are even thinner protection shields out there able to fit.
Any recommendations ?
in terms of full body protection, there isnt much choice out there.
BSE, Invisible shield, Zagg, Bodyguardz...they all use the same material pretty much. Its the material that we use to cover helicopter blades to reduce wear and tear. Its a thick, plastic type feeling material.
I believe that they ALL use the same material (some use different texture to it). I dont think your going to find anything that will fit properly.
If you were to find something, it would have to be so thin that it prob wouldnt hold up after sliding it and out of a case.
wrapsol is thinner than BSE/IS. that might work.
i have wrapsol on the back of my 3gs, not using any cases. it fit well under my incipio feather, but i love the feel of it being naked and not having to worry about scratches on the back.
Hmm Wrapsol ? Never much heard of it.
So how much thinner is it compared to BodyGuardz because from what I know, IS is thicker than BodyGuardz.
Around 0.2 Micron.
theres a pretty good thread on it..here i got it for you
https://forums.macrumors.com/threads/750727/
also check out their website. i have it on my phone. feels so much better than IS and BSE. its not as tacky as them, thinner, also gives it a matte look. im able to fit my incipio feather over it no problem and not lifting of the skin.
Will definitely check Wrapsol out !
Thanks alot for your recommendation, really appreciate it ;)
Anymore others out there having the same scenario as me ? :D
i don't think any skin will work because of the "tacky" feeling they add to the phone.
