moabal
605
3,206
I use a wireless CarPlay dongle in my car that uses Bluetooth/WiFi.
When I arrive home, my phone does not connect back to my wireless network automatically. Even though my car is off, it takes 5-10 minutes for my car to actually shut off power to the CarPlay dongle itself.
The only quick fix to this is to turn on and off Wi-Fi on my phone.
However, it does not seem like there is a way to automate this given Apple’s restrictions. At best it can notify me to run a scene when I arrive home.
Does anyone have any ideas how I can get around this?
Thanks
Edit: I figured out a workaround.
1. Create a new "Focus Mode" on your iPhone. I called mine "Home". Editing the silence notifications is optional. The only thing that you need to do is make sure that it auto turns on and off at the desired location.
2. Create a "Siri Shortcut" in the Shortcut App to Turn Off and then Turn On WiFi. Add "Wait X Seconds" as required.
3. Create a "Personal Automation" in the Shortcut App to run that newly created "Siri Shortcut" when your new "Focus Mode" is turned on.
It seems to work well. The only downside is if I go my office which is right next to my garage it will try to reconnect to CarPlay during that 3-4 minute window that the wireless CarPlay dongle is getting powered.
Hope this helps someone.
