ValSalva
macrumors 68040
I think the weight difference between the 16” M1 Pro versus Max means the 16” M1 Max may get slightly better fans and/or a better heat dissipation system. This is not the case with the 14” M1 Pro versus Max because probably the 14” M1 Max is simply too small to contain a more aggressive cooling solution. This may mean that the 14” M1 Max could thermally throttle under heavy loads. Only testing will tell.
