HJ24
175
38
United States
My macbook pro keeps connecting/disconnecting from power every 2-3 seconds, and chimes under this scenario:
1) Shutdown MacOS while on battery
2) Close Lid
3) Plug into power while closed
-It continuously chimes every 2-3 seconds and the light on the power brick turns orange-off-orange-off etc. I have to open the lid, and the shutdown again for it to stop and charge normally.
Does this have anything to do with using a power adapter extension cable you were discussing on a another thread, after a week's usage of your new 16"?
The fact that the power adapter is turning orange-off-orange-off leads one to speculate you have something AC wise amiss. Check with Apple store staff about that adapter maybe not working correctly when charging.
Seems like a bug. on one of the posts here. A user said apple confirmed this issue.
Reactions: HJ24 and Realityck
Interesting thread on this issue.
Reactions: HJ24 and white7561
