sjcaguy
126
29
I'm having a leather worker create a custom case for me for the iPhone 6s Plus I have on order. I only have a 5S on hand and he's working remotely, so I'm hoping someone can help me with this!
  • He has asked me to provide two data points about the camera assembly
    • Precise distance from the edge that it's closest to
    • The horizontal/vertical dimensions of the camera assembly.
  • I also need to get some dimensions/measurements on the speaker:
    • Distance from the edge that it's closest to
    • Length of the speaker cutouts
I've looked everywhere online and can't find these data points! Thanks so much to whoever can help.
AMAZING. That's perfect. Thank you. I'll send it to the designer and consider my side of things done. Phenomenal.
You're welcome. Glad I could help. I hope your case turns out just the way you're hoping it will. Congratulations and best wishes on your new phone and new case.
