Saw this on apples discussion forums.
Can people test this and let us know?
This can be incredible if true!!
"Re: MacBook Pro Retina display burn-in?
Nov 23, 2012 10:31 AM (in response to mittense)
I believe I have found a way to basically avoid this and keep it from happening. I own a plasma television, and since it is plasma, it is a burn-in magnet. I recently bought a MacBook Pro with retina display and it was delivered with an LG display. In 2 days, I started to see some burn-in around the menu bar area where it constantly displays the same image. What I did, was "break in" the display. It involves running a full screen slide show of some sort that involves changing colours and/or images that keep the pixels on the display always changing. I ran it for 10 hours straight and I have been successfully using my MacBook Pro with no image retention for 3 months. I have also had people come to me with this problem, some cases more severe than others, and have done the same thing and not one of them has had the issue again. I believe that the way the display is made it shares so characteristics with a plasma like display. You basically need to run a moving image that has all the RGB colours and the intermediate ones too. This gets rid of image burn I had and it also prevented it from reoccurring. This may help some of you, it may not. Out of the 7 Retina Display MacBook Pros I have competed this on, all 7 are now image retention free. It may be something for you to try. If this doesnt fix it then I would bring it into your closest apple store and present your problem.
Hope this provides some assistance.
source:
https://discussions.apple.com/thread/4034848?start=5730&tstart=0
source:
